Hey All,
I believe some of you have heard me mention in the past that I have an idle issue. It seems to idle high once the car warms up and then at times it will surge/hunt while sitting at a stop. In the past I have disconnected the evap purge system and that solved the hunting, but the idle would still rise too high after warm up. I have replaced the evap purge valve and canister with no results.
I noticed today that one of the wires for the connector to the IAC valve is severed and obviously not connected to the valve. Could this be the issue??? I pulled the intake pipe with the engine running and was then able to plug the hole for the iac valve, which instantly lowered the idle back to normal...
I am gonna go to the salvage yard here and hopefully pull a connector to replace mine. Until then though, is it safe to somehow plug the valve so it stops idling high???
Thanks,
Shane
Thanks,
Shane
