Thank you in advance for any help on this project:
I need to replace a couple of rear brake lines due to one of them bursting and others being very rusty.
The lines run from the L&R rear calipers, each to a rubber hose. Another line runs along the drivers side rocker panel
1. The lines look to be about 3/16, is that correct?
2. What about the fittings? What size should they be?
3. What about the flare? What type/style of flare?
4. If I end up splicing in a repair to the long line that runs along the drivers rocker panel what should I watch out for?
Thanks again for any help.
