Should an axle have play in the outer CV joint?
10K views 7 replies 5 participants last post by  bgkast
OK I misunderstood, thought this was the same NAPA axle with the bad tripod bearing.
Sounds like you have more play than I do in mine, with mine they feel tight but not like they are welded together, i.e. there is a enough play to tell the shaft and CV joint are two separate parts but not really enough to be measurable, if that makes sense.
You could always just do new OEM CV joints and new tripod bearings.
