Below is an excerpt from a key-off drain diagnostic that I wrote a few years ago. You should be able to adapt the procedure find your dead ground/short.
But first, to protect the wiring harness, you might want to buy a bunch of fuses instead of making a test lamp apparatus.
Just using the fuse as an indicator (much safer):
Unplug everything from the circuit (at the component end of the harness) and install a new fuse.
If the fuse immediately blows - the problem is in the wiring harness.
If it hangs in there, start reconnecting individual loads one by one. Check the fuse after each plug-in. When the fuse pops - you have located the faulty branch of the circuit. The problem lies within the last component to be connected. Inspect and repair as necessary. This is why you bought extra fuses - it may take several attempts as you experiment with the wiring (looking for the exact point of the failure).
Using a test lamp as an indicator (not for the faint of heart):
If you do decide to use a test lamp across the fuse holder, be ready to immediately kill the power (i.e. yank the test leads out of the fuse block) if the lamp goes really bright.
Make a 12-volt test light. Take a couple of tiny male spade type solderless connections (Stakons) and crimp one to each of the two test lamp leads. BTW - this procedure will be much easier if you use nice long leads for the test lamp. That way you can keep the lamp right near you as you work (more on that later).
Plug these into the fuse holder just as if they were the prongs of a fuse. Make it up well and secure it tightly so it can’t get yanked out as you move around.
Now look in your owners manual (sometimes it will give more detail than the fuse box cover) and see what things are driven by this circuit.
The lamp should be out or very dim with everything unplugged. Then, while dragging your test lamp around with you (see why I said to make it up with nice long leads) start re-connecting things one at a time.
Watch the lamp at all times. When you connect the faulty group to the circuit, the test lamp will dramatically increase in brightness. YANK IT OUT OF THE FUSE BLOCK FAST.
You have found the bad component group.
Repair it or replace as necessary. Plug everything else back in too. Check your work with the lamp.
Okay, what if you disconnected everything single thing in the circuit and the lamp is still bright (or a new fuse pops immediately)?
Either your owners manual is not providing enough detail and there are other things still connected to the circuit or, and this sucks- it is in the wiring harness.
Pay special attention in areas where the wiring can touch the frame or where it passes through a tight penetration.
The fault will almost always be found in the insulation of the wires (chafed through) or the lamp sockets (e.g twisted/bent contact springs touching each other).
Good luck. There are other methods to find a buried ground (the smoke test for example) but they are for professionals only. But with any luck, these methods should find and repair your ground.
