How to turn off DRL with Tech 2?
6.7K views 13 replies 7 participants last post by  BobSaabit
#1 ·
2001 9-3 Base. I just got a tech 2 yesterday and want to turn off the DRL's. I wasn't able to find where to go to turn off the DRL's. Does anyone know where I need to navigate to so I can turn off the Daytime Running Lights and make the light switch work normally? Thanks.
Discussion starter · #6 ·
I'm still working through the Tech 2, but I found the DRL setting in the DICE. I changed it to "Alternative 1". This turned off the DRL, parking lights on at the first notch, and then headlights on at the second notch. I didn't take out the fuse.
Discussion starter · #10 ·
Jake, you're right. Now that it's dark outside, I can see better. With the #15 fuse in, the parking lights stay on all the time. I pulled the fuse and now the parking lights are off. Turn one click - parking lights on, two clicks - parking and headlights on. Thanks.
