Hello all,
Just finished up my big turbo build on the saab and noticed that the temps under the hood are higher then I wanted. Its getting so hot that the coolant temp is heating up and not really able to cool down. Its also getting so hot that my fan melted!!
My main question has to do with the padding on the hood of the car. I see most people remove it completely but I did not. I only cut out a small section above the hood so that the turbo doenst accidentally catch it on fire.
Would I benefit from removing it completely? Is the padding holding in heat and not allowing it to dissipate properly?
Right now the manifold, turbo hot side, and downpipe are cermamic coated, heat wrapped, and the turbo has a blanket. The hood above the turbo also has gold reflective tape on it as well.
If you have any extra tips on how to keep the temps down, let me hear em
Thanks in advance!
Thanks in advance!
