21 - 40 of 224 Posts
Cutting the carpet and slicing the body(I personally just make two cuts, peel back the steel, then fold it back, couple strips of duct tape...done in a half hour) is THE way to go. The replacement WALBRO pump should have a barbed end just like the original. That being the case, just cut off the old pump with a razor blade, use a tubing vise to hold the tube, push the new pump on. There is enough fuel line to not have to resort to rubber hose and clamps.
Also make sure all the electrical lugs look good. Once in a while youll see evidence of overheating.
hkayssi said:
Thanks, I already replaced the pump but haven't plugged the lower part of that hose to anything and the car runs like crap. I was thinking it may have been related to this hose not being hooked up properly.
Did you make sure you bought the right type of hose.... It has to be for FUEL and has to be really tight.... (i bought the right size hose be the wrong type and the car run like crap also and wouldent start when it reach little less than a half a tank...... but let us know .... whats going on....
It's not that. The pump came with the hose and it fit perfect. This is another hose.
http://www.saabcentral.com/forums/showthread.php?t=61165
Maybe this will help; I have yet to do one of the newer ones...
It should be impossibe to switch the pressure and return line - even if they may seem to look identical....
The return line, I guess, just dumps its fuel thru the pump housing and then to the tank... As a guess, as this fuel may be warm, it is diverted away from the pump..
HK- Did you connect the tube to that nipple on the lower side of the top piece? In the pics, there is a corresponding nipple protruding from the top of the assembly but no clue to what it connects to, if anything. Perhaps this is a vent to allow air into the tank to replace fuel used?
That hose in question ,Hkayssi, must be part of the EVAP or fuel tank vent system,there should be another hose that connects to the nipple close by the electric terminals and then runs to the fuel tank neck. If the internal hose is not connected, I do not know what the repercussions would be, if anything...
Two questions, as I continue to have issues with my recently replaced pump.
Has anyone experienced problems with or replaced the o-rings on the check valves? If so, what size o-ring did you use?
Also, how flush should the retaining ring be with the top of the tank? Mine is currently NOT flush, but I don't know if that's typical. I don't want to try and torque it down if I shouldn't.
I'm still getting fumes into the cabin, though there is no obvious leak from the pump (at least there is no puddling of fuel on the top). Right now, I don't have the access hole covered, but I'm assuming that I shouldn't be getting fumes regardless. Perhaps I'm wrong?
You should not be getting fumes in the cabin. Seems your assembly isn't properly installed. It might help to view the picture in the recent post by Twitchie (posted Nov. 5) in a thread about a template for the access hole.I wouldn't try to force the retaining ring down. Better to remove the ring and inspect the installation, the pump assembly and the seal to figure why it isn't sealing properly.
hkayssi said:
Just an update, that tiny hose is pointed up and goes through the tiny hole on top of the assembly. Like EW said it's for venting.
I just walked outside to check this fact, and the plastic nipple is solid on the inside, so there would be no venting. This is on a '96 900 turbo convertible.
What nipple? I'm talking about the unconnected part of the the little hose; it goes up through the fuel pump's top cover's round hole on top. It's diffrent on yours??? What is it connected to? If it's different on yours, I'd like to know please :D If it's hooked up wrong it may be the cause of my crappy idle when cold (not a vacuum hose, IAC purge valve, etc. I already tested all those)
HK, I just double checked, and on my car that nipple is sealed on the inside. The nipple is there as shown below, but it is just solid plastic in the center.
Hope this helps in some way.
How to fix Broken Check Valve Retainers?
Thank you very much for the fantastic thread on how to replace the fuel pump. It has saved us hundreds of dollars on an otherwise costly repair. You were extremely thorough, however I have one question:
I noticed that the yellow supply line check valve retainer tab is broken in the photos. Mine snapped too. I thought I was being careful, but as I learned, and you admonished, it is critical to use 2 screwdrivers, one on each side of the tab to release it from the check valve.
How did you repair the broken retainer tab? Did you fabricate a clamp of some sort? Did you epoxy the broken piece back where it belongs?
Please tell. Without a good solution, the supply line will pop out of the pump and fuel will gurgle all over the back seat--kind of scary.
Thanks again--
