Exhaust manifold crack repair ?
3.1K views 11 replies 9 participants last post by  ct
#1 ·
1986 c900 8v NA
I have a nice crack in my exhaust manifold....anyone ever patched/repaired it before? If so, what did you use?
thanks all-
H
#5 ·
Exhaust Manifold crack
The manifold (Not the engine) has to come off. That is the only way they can weld the crack which continues at the bottom. The removed manifold is then bolted temporarily to an old head and welded. That temporary bolting is to stop the manifold from twisting from the welding process. I suppose that if you do not have an old head you can bolt or clamp it to a strong plate.
Before having an indy do it, I tried bogging up the crack with araldite. Smells terrible when the heat of the manifold burns it off.
When it cracked again a year or so later I had a second hand later model 16 valve manifold put on and no cracks some 10 years later.
