I purchased this MOST loopback connector from Etadyne because my AMP1 stopped working (symptom: radio stopped working, no sound for directional signals).
The installation instructions call for separating a two-pin optical cable connector from the main connector, but I can't as it all appears to be one integrated housing into which the fibre optic cables run directly (see thumbnail).
So, can anyone tell me:
1) how to remove the fibre optic cables from the main connector, since there's no separable optical cable connector?
2) how I can still make use of the loopback connector since it expects the insertion of the two-pin optical cable connector on one end?
3) an alternate way of creating the loopback? (at this point I've removed and totally disassembled/torn apart amp1, so it can't be part of the solution)
Thanks
Thanks
