9-3 V6 Aero 6 speed auto transmission issues
46K views 63 replies 20 participants last post by  JDavidAero
#1 ·
I got a great deal on a 2006 9-3 Aero with the auto 6 speed. Only 47k miles, great shape (except for the AC buttons :) ).
It has been a bit klunky with the 1 to 2 gear shift since I got it.
I did the transmission fluid rotation (not quite done yet, but I've got 3 quarts cycled now), and if anything it seems a bit worse rather than better.
Do these things just "do that"? Or will chipping the car with something like the Vermont Tuners setup clean it up? Or do I have a servo failing?
Most of the time it works well. But occasionally, more often when cold, it will pause when I am manually trying to make the 1-2 shift via the buttons. If I do it just right (like I would do a clutchless upshift on my motorcycle) it goes well. But otherwise, it can lag, let the engine rev, then slam into gear.
In auto mode the car sometimes acts a bit confused, particularly if I barely roll a stop sign. If I come to a complete stop it's generally well behaved.
I don't need to pretend this is a Ferrari with a flappy paddle, so if you have to do the RPM matching thing to get the buttons to work anyway, no whining from me. I really just consider the "manual mode" to be a good replacement for the "winter button" my beloved 2001 9-3 had (may it rest in peace).
If it is a servo, how hard are they to replace? From what I have heard, I thought it could be done with the engine in place. I have access to a lift and am a pretty good wrench (rebuilding old motorcycles from buckets of parts, including fabricating parts). Cars aren't much worse, just more annoying to get into, and more likely to remove a toe if I do something stupid. ;)
#28 ·
#29 ·
OK, barely made it home. No bad sounds from transmission, but when it tries to shift, it can't go into gear. Sometimes it will stick in 6, sometimes in 2, once in 5. You can try and force a shift with the flappy paddle in manual mode, but it just blinks the gear you command, then blinks back down.
Everything I can find suggests that this is a really common failure on this transmission, not just on Saabs, but also in Mini's and Volvo's also, where it is also used. I suppose the good news is that, aside from this valve body, its supposed to be a pretty tough transmission.
Looking at the WIS, this doesn't look that bad. The B284 is apparently the V6 engine that has this 6 speed auto.
Chapter 1... Remove the "valve housing cover"
Put car in neutral and put on the parking brake.
Drain cooling system after relieving pressure.
Jack up car.
Remove the "chassis reinforcement, front subframe, cv, petrol". That is 6 bolts and a big chunk of metal. Not bad though.
Drain transmission fluid.
Remove oil cooler hose connections from gearbox
Remove charge air pipe
remove lower cooler hose
remove battery cover, battery, battery cover lower section
remove and move aside intake hose from turbo
remove charge pipe hose from turbo and lift away pipe and hose
remove bypass valve from turbo
remove solenoid valve from turbo
Remove cooler hose from thermostat housing hose connection
Disconnect oil pipes from cooler connections
Remove dust cover from upper pipe
detach upper oil pipe from automatic transmission using special tool
Remove dust cover from lower pipe
remove ground lead and clip at starter motor
Remove holder and connector and wiring harness (4 connectors or so)
Move wiring harness out of way
Remove valve housing cover.
Chapter 2.... remove valve housing
Unplug solenoid valves connectors (8 connectors)
Unplug engine speed sensor connectors
Remove the temperature sensor
Move wiring harnesses out of the way
Remove cover
Remove remaining screw and unhook clutch rod
Lift valve housing upwards
That's it. Lots of steps, but only one special tool (that looks pretty simple) and nothing that looks that difficult.
Is there a way to clear the adaptations from the transmission without the special Saab computer?
#37 ·
I wouldn't mind paying for some tech2 time anyway, if it means I can turn of the "auto lock the doors for me" feature. I hate it.
What happens if I don't do it? Will the transmission eventually relearn new patterns? Or will it be fubar (or not even functional) until I go through some kind of digital bonding procedure with the Tech 2?
Thanks for all the help.
#39 ·
Replaced my valve body back in September. Written up here;
http://www.saabcentral.com/forums/showthread.php?t=344529&page=5
Never ceases to amaze me sometimes we seem to have parallel universes at play here in this forum LOL.
Went with a new unit as reman option too expensive for me with all the shipping given I am based in Australia.
No problems with new unit so far. Did a lot of research on part numbers as valve body has been updated several times. Anything that is listed for a NG 9-5 or Caddy SRX is going to be an updated unit with stronger more modern solenoids. My tech commented on how different the solenoids looked on the new unit compared to the old one.
Also my tech reset the valves with Tech 2.
#56 ·
#44 · (Edited)
Ugh! The parts I am doing right are pretty easy. The parts I am doing wrong, not so much. ;oops:
When you disconnect the transmission cooler lines from the transmission cooler radiator, there are big freaking nuts on them. If you look at the WIIS, it says "remove dust covers and snap out oil lines". The "dust covers" are bold black lines, and they are obviously the nuts I am looking at.
Except they weren't. They were little black collars behind the bolts, which reveal the little clips, that can be easily removed with a dental pick (and not just the SAAB tool) to release the oil lines.
Turns out (sigh) if you remove both those big nuts, you set free some sort of captive block that is *inside* that stupid radiator. Complete with O-Rings on the *inside* of it.
If you do this, and have enough patience, you can remove the bottom cooling hose and fish out one or both orings (only my bottom one came off, thank goodness). Then I took a small screwdriver, and levered up that floating assembly until it was lined up with the holes again (not easy and it takes some push from the bottom, pin from the top, reposition and push from bottom, etc). Then thread in a dowel rod into that bottom hole to hold it in place.
Then you can work the o-ring back in carefully, through the hole, then go back to the top. There, you can now correctly remove the little clip thing and disconnect oil line, then put a lot of hope and RTV on the big nut things, and then thread them back in and re-capture that inner floating piece, being careful not to torque them down too tightly so you don't break the plastic body of that part of the transmission cooler.
I am still reassembling, so no idea if it will hold. If not I'm guessing I will need at least a new transmission cooler, and have to pull the radiator, which will probably mean disconnecting the AC, which I *really* don't want to do.
We will see....
#45 ·
(for the record, that drawing and description ***sucks*** to communicate what you are supposed to do... Would it have killed them to say "Do NOT unscrew the oil line collars, they must remain captive in the oil cooler. Remove the oil line retaining clips that are behind the dust covers.")
So anyway... "Do NOT unscrew the oil line collars, they must remain captive in the oil cooler. Remove the oil line retaining clips that are behind the dust covers."
Hope this helps some other 2006 era Aero Saab guy somewhere....
#48 ·
Post job wrap up...
Here is my after action report... :)
Summary:
The WIS does a good job of walking you through the whole process with three exceptions (described below). Follow it.
The RevMax valve body seems to be fairly priced, and overall (about 500 miles since it was replaced) seems to be "almost perfect". I have had exactly one (out of 100) missed shift after a very hard acceleration after a very hard right turn since sorting out all my mistakes with the replacement. Before the repair, the missed shifts would have been 100 out of 100 times on hard right turns, and 50 out of 100 times even on moderate right turns. At the point I broke down and did the repair, the car would not even shift out of 2nd gear going in a straight line.
Fluid levels are important, follow the manual (with car running, fill until about 400 mL comes out the drain tube, plug drain tube, pour in 400 more mL).
== Elaborations for service procedure writeups ==
The worst one is removing the transmission cooler lines to the radiator. The line art illustration says "remove dust covers" and points to a highlighted drawing of large nuts that go into the transmission cooler (which is an internal part of the radiator). So of course I removed them. Which of course was wrong. The actual "dust covers" are more like o-rings, and the thing you remove is a little clip on there that then allows the transmission lines to just snap out. When you do it wrong, this is a big problem, as the transmission radiator is only captive due to the two fittings you just removed. You remove the second one, and you hear the clunk as the internal transmission cooler drops to the bottom of the radiator (which is still in the car, and which would be a major PITA to remove).
To fix this, if you care, pull the bottom radiator hose, and then use a variety of "pointy but not too pointy" things to work the internal transmission cooler back into position to where you can get a wooden dowl threaded in the bottom fitting to hold it in in position while you first get any o-rings that fell down back in position (from the outside), liberally apply both RTV and prayers on the fittings, put the top fitting back in, remove the dowel from the bottom, and then finally put the bottom fitting back in. This seems to be holding. If you complete this successfully, you are now qualified to perform laproscopic surgery on most small mammals.
The next comment I would make is about applying the RTV to the valve body. I have no idea how on earth you could do this, then get the valve body into position, without spearing RTV all over God's own creation (and removing it from key parts of the mating surface). Likewise, I don't see how it would be possible to put it on the transmission side and not disrupt it before getting the valve body in place. So I just cleaned both surfaces perfectly, put the valve body nearly in position with a 1/2 inch gap, and then carefully applied the RTV all the way around using a bamboo kaboob stick and a lot of patience. You can get everywhere if you are patient. This might have held, I have a few drips on the driveway, I will have to wait and see if they are dripping mess from before the job, or drips from after. There isn't much coming out.
Finally, the manual doesn't give much attention to the wiring harnesses down there, but should. Unless you have two people doing the job, it is very difficult to wriggle an oily 20 pound valve body up through the very narrow hole you have created at the top that has wiring harnesses on all sides. The net effect is that it is very easy to beat up wire harnesses or wire connectors. I also had a problem where when reseating the connectors they must have been dirty or poorly seated, as I was getting communication errors thrown (trouble codes like requested torque not available, transmission bus unreliable, etc) the first time I drove in the rain. I pulled the connectors, hit them with contact cleaner, and re-seated them firmly, and the problem seems to be fixed. I would have also used just a little dielectric grease, but I couldn't find it in my tool box (it of course was right where I thought it should be the next day).
The car now runs better than it ever has since I bought it insanely cheap with 50k miles on it (no doubt traded in to the BMW dealer I bought it from because the transmission was starting to get wonky and a traction control failure was up on the SID). I'm at 100k miles now. Its nice to be able to push it and not be terrified that it will miss a shift, rev wildly, then come crashing back into gear.
So, a tedious job, but I can't complain
#51 ·
You don't have to pull the radiator, but you definitely have to disconnect those lines to get them out of the way.
Once you understand how the clippy things work, it's trivial to do it right, much easier than doing it wrong in fact. Just pull the little wire clip, and pop out the fitting. And you don't need the special tool to put the wire clips back... I did it fine with a pair of forceps and a screwdriver.
#52 ·
3 month update... probably close to 5k miles on the repair and it is still holding up fine, and working better than ever. No missed shifts no matter what I do.
There are a few odd cases where I can fell it stutter up and down a gear (or maybe the torque converter is locking in and out) when I confuse the transmission with odd inputs (like I can't make up my mind if I have enough room to pass safely and bounce quickly between accelerate and coast a few times in rapid succession). That may be just the way this transmission works, and indeed how a sporty auto should work. I'm giving it a mixed message and getting a mixed response.
Normal driving, hard acceleration, and hard deceleration are all perfect.
I didn't see the core charge refund yet, I emailed RevMax about that today. It may be there, I haven't looked for it. To return the old core, you reuse the same packaging material they sent you the rebuilt part in, and you use the preprinted package label they gave you. I don't think you pay shipping again, but I'll have to see if it got deducted from my core charge or not to be sure.
Anyway, so far will stand as one data point who can recommend RevMax as a source of rebuilt valve bodies for the Saab 6 speed auto.
#59 ·
Good read. Wife and I traded in our 2001 Saab 93. We bought a 2007 Saab 93 Aero Saturday last weekend from Infiniti of Bellevue in Bellevue WA. 117k one owner and was a Washington car only. It was thee best Saab 93 in a 500 mile radius. Years we looked at were 2006 to 2011. Being one owner really helped. Plus Aero had every option you can think of or I think anyways. We got a very good deal on the car also. I do notice a slight transmission hickup when we test drove it and after we bought it. Nothing to be bothersome at the time. They were not going to budge on the price. But we got a good deal still. Today after getting groceries. I noticed the transmission would stall some and shift a bit hard into 3rd. Would clunk when down shifting under 3rd. We were driving around the outdoor mall (the village) here in Meridian ID looking for the entrance for the theater. It was bad and sounded like loose transmission mount but it's not. Manual shifting seen to be okay. I felt with enough problems with the 99-02 Saabs and will still deal with it as we have a 2002 Viggen Convert. I am taking from reading the thread that I will need to buy the new updates valve body? I can do it myself no problem but it's the time for it. Winter is setting in here and I do have a garage at out appartment. House should be done in February. Micheals Auto in Boise works in Saabs still and has a lot of them. But I cannot drop $3k on a repair. Be worth it yes if that means we can get 10 plus years our of her. She is our family car but the wife will mainly drive it. Someone said the ecu learns your driving? This true? I am not really hard on her and do not want to be. Want her to last. Any info will help. Just hurts knowing I have to do worm on her a week after getting her.
