21 - 40 of 41 Posts
Just in and out, very simple, if you arent familiar with spark plug re and re then you might be best off using a torque wrench so you don't over tighten until you get a feel for how tight the spark plugs should be, you have to careful when tightening them in the aluminum head.
I just watched your video, I think you have noisy accessory pulley bearings on the serpentine belt.
Discussion starter · #26 ·
Alright thank you!
You mean the sound from the engine it self or when revving? I remember i recently got one of the pulleys replaced because it had a crack but thats all i know about pulleys and belts
Discussion starter · #27 ·
I was also wondering about this. I just got my car back from the mechanic and im seeing this thing and i feel like i havent seen it before? Its some oil there and when ive looked up the cars engine bay on google i find out theres something supposed to be there i dont have? Is this normal or am i missing something?
That is a vacuum pump that is used on automatic transmission cars for the power brakes.
The third picture shows the plug that is placed there when you don't need the pump, you can get a new plug and seal for it.
Discussion starter · #29 ·
ahh alright thank you ! Just found out its the original spark plugs that the manual books tells u to use and the whining doesnt start before the engine gets to normal temperature. Also realised smoke comes from the right side of the radiator like faint smoke you barely see it. Idk if you know what that is?
Discussion starter · #35 ·
Yes I did. Those are correct ones.
What you want to with your car?
Basic maintenance, tune, something else?
Right now I just want to get the oil and turbo fixed. After that I was I wanna start looking at exhausts and similar small upgrades to start off.
But my main goal is to just have it easy tuned and work on it here and there but at levels where it’s safe for the engine if that makes sense
Discussion starter · #37 ·
First you need to solve your oil issue.
You want tune, then I recommend Mitsubishi turbo, same as Aero has.
That’s the td04 right? And it’s safe for the 2.0? What extra or what do I need to change compared to the garret one that stands in it?
I’m thinking of starting with the system flush next week and see if that helps. What bars should the oil pressure be at when idling and in rpms?
Discussion starter · #39 ·
You might need bigger turbo when you go higher than original can.
I personally drove almost 10 years 2006 9-5 Aero manual which had 315WHP and 479Nm.
It had stock turbo fuel pressure and intake, bigger injectors and full 3" exhaust.
21 - 40 of 41 Posts
