Traction Control Failure, Apparent Empty Tank and a total non start of the car.
6.6K views 16 replies 5 participants last post by  Mimmi
Check the ABS connector, unplug it, check for any corrosion, put it back and try to start the car, if still no crank, then jump in 1&13 and 2&14 on the ABS connector (last 2 pairs of the pins towards the firewall), if you can start the car, then ABS module could be bad, this is more common issue on 2.8V6 engine though.
