Soft Top Manual Operation Only + DTC's
15K views 8 replies 4 participants last post by  Mimmi
#1 ·
I'm trying to get this convertible top operational. Just got my Tech2 clone connected and got this info.
Not sure where to start troubleshooting on this thing. Wondering if any of these other DTC's could stop operation of the soft top? Such as this angle sensor?
I'm also having trouble finding the soft top info in the WIS
#4 ·
So, I pulled the trunk liner and inspected the pump & STC. Wiggled wiring etc. Hooked up the Tech 2 and got code STC B1010 08 .
I again tried the soft top motion on the tech 2, same negative response as in the pic.
I then tried the sensor test.
Results - Tonneau Cover Up, 6th bow latched, Main Cylinder Up.
So, I'll be trying to locate these and see if I can test them.
#5 ·
I located the main cylinder up magnetic hall sensor. Hopefully I'm testing it correctly. It has 3 wires. I'm getting 11v on 2 leads, then 8v on the other using dvom testing to ground. cycled the cylinder up/down a few times - no voltage change on any leads.
The other 6th bow latched requires some disassembly of the top, so I'll hold off on that.
I'm not that great with electronics, so thinking I'm going to see if I can locate these 2 sensors and roll the dice.
#6 ·
Just wanted to update, maybe this will help someone.
I had 6th bow latched right and main cylinder up/down show bad on the tech 2 sensor test.
I replaced 6th bow latched right sensor, but nobody has this main cylinder up/down sensor. After shopping around I found a UK site Sabbits - they got it for me in half the time and $50 cheaper than the US retailers I checked.
Changed both these sensors, cleared codes - then tech2 says 6th bow latched right reading bad again. Weird - this is a new sensor.
Cleared codes again and disconnected the Tech 2. Hit the switch and top is now operational.
