I am in the middle of fixing my air distribution flap and couldn’t figure out what this yellow thing is for, does it control the part that I marked in the second picture, and if it does,what does this whole thing do
Thanks a lotthere are some good instructions in WIS and a few very detailed TSB's for repairing the HVAC system, but i found this information hard to locate (in WIS and find the TSB's) , and not very intuitive to access.
Below i attached 3 of the main ones i found useful to understand my own HVAC system (RHD 2004 model), one of them has good detail on the specific replacement parts available for repairs
I’ve heard the same advice before,so I’ve decided to ued plastic part ,and thanks for the replys,they’re very helpful👍do note that with some of the HVAC "sleeve" repair parts available (for some of the plastic levers), there are both metal and plastic type replacement versions available for this. the saab OEM version is plastic (but is an improved version of the same original part), the URO (and some other after market brands) are metallic versions.
Mimmi (from this forum) has previously advised to use the plastic versions (and he knows his saab parts). i think the logic is that if metal replacement parts are used for this, then the weakest "stress point" in the mechanical moving parts of the HVAC system would then be a deeper (eg less accessible) part of the HVAC system, and if they break the whole HVAC system might needs to be replaced.
