Hello. My wife’s 2006 saab 9-3 2.0T is vibrating under power / open throttle. It’s getting the P0304 misfire code. The CEL flashes sometimes if you gun it, but it doesn’t stay on – the P0304 code sticks in there though.
“” Recent work, I replaced the seal in the power steering pump because I had the issue where the motor oil was getting in with the power steering fluid. Everything has got oil on it, but it stopped leaking. Around the same time I think I did and oil change and a plug replacement.
With the vibration I was worried about a possible transmission issue, so I did a partial change on the ATF.
I also noticed the front motor mount has a little flap of rubber hanging out. It looks pretty solid otherwise though.
So, what do you think the most likely issue is?
Coils/Plugs ?
Fuel Pump ? Injectors?
Transmission Issue (misfire is separate issue)
Computer/Electronic (about a year the car when into limp mode a few times, but I disconnected the battery overnight and that fixed it)
Coils/Plugs ?
