Im getting an error code as follows-- P0033 Turbo charger bypass valve control circuit. Im trying to find out what the cause and fix for this code is, if anyone has any idea, please let me know.
I first got the P0033 fault code about 6 months ago. I replaced the two solenoids and the problem was gone. Then a few weeks ago the code popped up again. So I decided to change the diaphragm and also do an instruction to give something back to this site because of all the help I’ve got from here. The old diaphragm looked worn with small cracks and holes in the first layers of it. So far the code hasn’t come back and the car seems much smoother now when releasing the throttle abruptly. I’m almost certain this fixed the problem.
So here’s an instruction with some pictures explaining how to change only the diaphragm for the bypass valve on the Garrett GT2052 turbo (the “little t turbo”). I think it’s similar for the Mitsubishi TD04. It took me less than 1.5 hours to do this but that was with great carefulness not to do anything stupid (I do not have much experience with cars). It’s a little bit tricky because of the narrow space. A professional mechanic should have no problem doing this in approximately 45 minutes.
You may want to start by disconnecting the battery to reset the fault code. Then do the following steps:
1. Loosen the hose clamp for the large hose that goes to the air filter and disconnect the connector to the mass air flow sensor right next to it (pull it up and out).
2. Unscrew the 5 torx screws and unhinge the two plastic hinges to remove the whole top of the air filter box.
3. Disconnect the 3 small vacuum hoses (red) to the solenoid (boost pressure control valve). Then disconnect the connector to it by pressing it down and pulling it out (blue). Remove the solenoid by pressing the small plastic piece down (yellow) and slide it out . (I’m not sure if you have to remove all 3 hoses and put the solenoid aside, but I did that to get some more space. At least one of the vacuum hoses needs to be removed).
4. Remove the large hose (that goes from the turbo to the air filter) by now also loosen the second hose clamp located where it connects to the turbo.
5. Carefully remove the bypass valve by unscrewing the 3 bolts. There’s a spring inside it that has some force in it. I would definitely recommend you to put something below the BPV in case you would drop something down the engine bay. I put a big plastic bag below it as you can see in the picture.
6. Replace the diaphragm and assemble it back again. It’s a bit tricky to install it back on the turbo because of the narrow space. I found it easier to install the BPV assembly back by having 2 of the 3 bolts in it at first to not dislocate the gasket and then put back the last one.
7. Put everything else back in the opposite order.
I hope this can help someone.
I'm have the same damn issue with my saab, its a 2004 9-3 linear. do you think i'd be able to get away with just cleaning the assembly?I first got the P0033 fault code about 6 months ago. I replaced the two solenoids and the problem was gone. Then a few weeks ago the code popped up again. So I decided to change the diaphragm and also do an instruction to give something back to this site because of all the help I’ve got from here. The old diaphragm looked worn with small cracks and holes in the first layers of it. So far the code hasn’t come back and the car seems much smoother now when releasing the throttle abruptly. I’m almost certain this fixed the problem.
What rubber part? The OEM diaphragm is $230 at its cheapest with the Forge at $150I followed most of the advice here, plugs, vacuum hoses, plug wires, etc. with no luck. It ended up being the solenoid and I splurged for the Forge. No codes since. I still have some vacuum hoses to replace and maybe that will get rid of an annoying engine surge when it's cold and damp. However, the rubber part would probably have worked just as well for half the cost![]()
We have the same car then heh.Sorry, I should be more specific (and more patient when typing on a mobile device). I have an 03 Linear (small t). There is a rebuild kit for the bypass valve on my car with a new diaphram, spring, etc. Apparently the same part was also used on Volvos and the rebuild kit is even cheaper if you get it from a Volvo site. I just like shiny things so I went with the Forge.
Shouldn't be difficult to find hi temp grease. Maybe even oil since there would be some left over from the PCV.Very true about the diaphragm. However, mine lasted to 130K miles before an issue. BTW - I was told that the Forge does need to be greased every year or so to retain a smooth action. It wouldn't take much due to the tight tolerances. I have no idea what type of grease - something with high heat tolerance. Also, the center part with the vacuum nipple on the Forge can be rotated without loss of effectiveness so you don't have to worry about other parts interfering with the hose. Some people had posted about this.
