9-5 Won't start, good battery, clicking noise under hood
Dear all,
I really need you guys' help because my SAAB is making me frustrated. It's a long story but I'll try to make it short.
I have owned a 2001 SAAB 9-5 SE V6 for 3 years and now it has 14K miles, mostly for commuting to school. Automatic transmission.
Four weeks ago I had my hose replaced at a local mechanic because of the coolant leaking. Three days after they replaced the hose, the car happened won't start on campus.
The symptom was:
1. When I turn the key to ignition, I hear a click noise then the car dies. No lights on, no display on dash board, no electric. However, I could hear continuously clicking noise under the fuse box under hood. The first thought to me was the battery dead so I called a friend to jump start for me. But, nothing happens when the jump cable connected. The clicking noise just won't stop even though I pull all the relays out from the fuse box.
2. Then I disconnected my battery, the clicking noise under the fuse box stopped. With the jump cable directly connecting my friend's battery and my power cable, turn the key. The car tries to crank but still won't start, sounds as if there was not enough current.
3. Connect my battery back on, with jump cable connected, waited for 20 mins, turn the key, the car dies again as described in (1). Then I found that if I disconnect the negative end of the battery for a few minutes then reconnect it, I could power on the car. Everything works, and no check engine lights on. But as soon as I try to start it, all the power disappears.
4. I removed the battery and took it to the Autozone. They said the battery was good and was 99% charged.
5. I left the car on campus for two days. Then I tried again with jumping cable from another car. It started immediately! I didn't know what was going on but it ran really good for another few days till died again. The same symptom as (1,2,3,4).
6. This happened three times. At first I thought it just won't start when hot, but yesterday morning it also won't start after staying for one night. Battery is always fully charged.
The problem to me was I don't know when it won't start, and when it will start again. If it was because of the starter, I should not be able to start it now and then, right?
I searched a lot only found this guy's symptom quite similar to mine: http://www.saabcentral.com/forums/showthread.php?t=233071
As he said, the reason was because of the bad connection of the ground connection on the thermostat housing, the only difference was his seems to be a V4. So I spent an hour to find the thermostat housing. It's a bit difficult for V6 because I had to remove all the intake manifolds, you know. But I found there is no ground connection on V6's thermostat...
I also did a diagnose following the SAAB WIS. I think I could hear the starter motor solenoid kick in when attempt to start.
Thanks to you guys for reading this much. I love this SAAB but as long as it's not getting me into trouble. Any advice is appreciated!
Dear all,
The symptom was:
