9-5 Head Unit Upgrade ?
20K views 10 replies 7 participants last post by  jaiko
I would seriously consider putting an Android head unit in the car. I put one in one of my cars and love it. I bought an ATT hotspot that I plugged in as well so the Android has its own internet connection. I installed Waze, Stitcher and Pandora on the radio so it has access to all of my stuff. And on top of that you can use a Bluetooth OBD connector to get Torque diagnostics in the middle of your dash.
Oh, and they have direct connect for the steering wheel controls so no extra box/programming. It's all in the unit.
Make sure you get one that has front-to-back fade, some of them don't. Often times you can tell from the screens of the Android app working.
And finally, I got one without a DVD/CD slot since I never use it, screen is bigger. But I've not yet been able to find a bezel to fill up the gap in the dash. A friend of mine volunteered to 3D print one for me, I just have to do the work to get him a CAD model. But with the project to swap engines in my son's car I've been busy
they're cheap too. Mine was $180 shipped. (although it does have an older version of Android, but I really didn't care too much)
I used the Clarion DDIN cage in my 03 when I put the pioneer in. When I did the 02 with the android unit I used the original cage from a Saab
I did this primarily because I see the one in the 03 "sagging" since the back is not supported properly. The original Saab cage has a back support. But I had to cut the original Saab cage up a bit since there was metal where the connectors go. I got an extra from a junkyard for $4.00 so that if I ever want to put the Saab one back I can do it. A much better fit in my mind.
The DDIN radio fits in nice and tight. Like I said before, the only challenge is that I've not yet found a faceplate and might have to make one.
use the Saab cage, get an extra from a junkyard since you might have to cut it up a bit depending on where connectors go. (if you buy a unit without a CD they are getting quite thin at this point so that would not be an issue)
Some minor mods and it'll fit just right since it's designed to go there.
