screw that goes inside the key fob
774 views 7 replies 4 participants last post by  steve12955
#1 ·
where can i get a new one?
this is for a 2000 9-3 coupe.
mine looks like it is stripped so i wanted to replace it.
thanks
#2 ·
It's probably not the screw that's stripped. The screw threads into the other half of the keyfob and it's the plastic that's stripped. I suppose you can fill the small hole with a drip of epoxy and then re-thread it. Or, you could carefully heat the plastic and squeeze the hole to deform it, then re-thread the screw. But, it's so small that the heat would melt the surrounding area.
