saab 9-5 oil change
1 reading
30K views 20 replies 9 participants last post by  krawczuk
#1 ·
i drained my oil out of my car and i put 2 quarts of 10w-30 in there and when i cut it on its still act up and turns off after a while and when i look at the oil it smokes out.
if anybody have any advice i would greatly apreciate it
#3 ·
i was using 10w-30
before i put the oil in it was running good but was overheating
smoke was coming out of the motor oil resevoir...
but now my car is smoke out the exhaust pipe but it wasnt happening before i did the oil change (when i try to start my car up i see a fausset check like in orange below the heat gauge.
#21 ·
hi, you know what ???? i`ve owned 2 saab s, and EVERY time i do a oil change it would blow smoke when i started it up in the mornings , or after a long period of non use..
the first saab blew smoke of an on for about 2 weeks , me second saab blew smoke for about 2 days..... then it was perfect....
really weird only done straight away after a oil change ????
mark k
#5 ·
2 quarts ofpeak motor oil and castrol gtx high milage motor oil
yes it was loosing coolant,
but also i put ow-30 oil in before i drained it,
it doesnt over heat now but when i crank it it blow white smoke out the tailpipe and the engine make weird noises like its caughing , and then it cuts off
#6 ·
Whoa.
If you only put 2 quarts back in, you have LESS THAN HALF of the oil you need. Stop trying to run the car and fill it up properly. Properly is when the oil level hits the flat section of the dipstick. it should take about 4.5 quarts from empty.
Buy the correct oil. Very strongly preferably full synthetic, but make sure that it meets ACEA A3 spec.
That orange faucet light is your "Check Engine" light (CEL). Go to an auto parts store and have them read the engine codes. Google the codes or report back here.
I hope you haven't done too much damage yet. Good luck.
#15 ·
And if its not already been done on a 4 cylinder engine please get the sump / pan dropped and the pan, screen and pick up cleaned!
#16 ·
Please do not take offense because I don't mean to offend you.
But have you ever done this before? It sounds like your troubles go well beyond a simple oil change and you probably should to have your car towed (do not drive it and risk further damage) to a professional. Otherwise you risk compounding the problems and possibly damaging your car permanently.
#18 ·
Thats what post #6 said too..............
