Changing over to full synth tonight. Wanted to flush the engine at the same time, but I remember seeing a post awhile back that said it may not be a good idea to run additives/flushes. Any advice?
could you please specify what type of solvent to use? one bottle only? thx.fabric said:An engine flush of this type is a bottle of solvents, basically, that you put in the old engine oil before you change the oil, and then run for about 20 minutes. You drain this oil, so it's not left in their for very long.
I used the AMSOil flush. It said one bottle, although you needed to make room by removing an equal amount of oil - took care of that by putting in a new filter.solid155 said:could you please specify what type of solvent to use? one bottle only? thx.fabric said:An engine flush of this type is a bottle of solvents, basically, that you put in the old engine oil before you change the oil, and then run for about 20 minutes. You drain this oil, so it's not left in their for very long.
