alu36 rims vs alu46 rims- rarity factor?
3K views 5 replies 3 participants last post by  Diggs
#1 ·
A not so local (ie 3 hours in the car) wrecker/seller has the alu46 set up for sale.
The source car is listed as 9-3 linear, year unknown.
I'm curious - how rare are alu46 rims (3 spoke Double Evo) compared to the alu36 (3 spoke double y)?
I see lots of the double y's but I rarely see the Evo pattern.
Observations?
#2 ·
ALU46 have 41mm offset and were specced for NG9-3, double Y have 45mm offest and specced for OG9-3/OG9-5. Not a big difference, either should fit the same.
I believe the double Y came standard on deluxe OG9-3, which would account for their prevalence. I don't know if the double evo was standard on anything (definitely not a Linear). Saab had a lot of wheels that were in the accessory catalogue. Good sets of an accessory wheel can be hard to find in my area--one or more will be bent from potholes. Maybe be better in the Antipodes.
#3 ·
Thanks Edt.
Yes, the Double Y became standard on the Aero/(SE) here in 2001. I have the older 16" Tri-spoke version (alu26) which I think have a 49 offset.
I hadn't thought about the offset yet, thanks for the heads up.
I'm guessing the previous owner added the Evo if it wasn't standard.
#5 ·
Thanks, Diggs. Yes, the photos I've seen show some scuff marks, and the tyres are reported as no good. That's ok because I would put new ones on anyway.
With the offset difference between an OG 9-3 and NG 9-3 - how do I solve that? Do I use spacers?
