Are these any good? I want to replace my rotors and these are $20 cheaper than the genuine Saab rotors.
Every Zimmerman rotor I've ever used or installed is equal to or better than OEM spec. I use Brembo OEMs on my BMW, but used Zimmermans on my old VW.Kermit said:Never heard of 'em.
The slotted rotors do help expel some of the heat put forth by good pads. It also helps scrape off the pad when it starts to get coked up too. I run regular rotors though... so...Raven18940 said:I'm not looking for anything fancy, drilled and slotted rotors are a hassle I don't wanna deal with. Plus it's extra $$$ and to be honest the car stops more than fast enough as it is. The extra stopping power is gonna come from the PBR Metal Master pads I'm putting on. :cheesy:
I am confused, a warped rotor is a sign of to much heat. The idea of grooved or drilled is to stop the warping.. No cracking with a grooved disk only a slight possibility with drilled, having said that I have never seen a drilled one crack in recent years. With a grooved disk and a fast road pad the abs doesnt kick in as quickly. I used a metal compound pad a few years back before the ceramics were available, they used to get so hot on the smooth disk that red hot iron fillings used to pit my alloys.Raven18940 said:My problem with slotted rotors are A) they cost more, and I beat up my brakes quite a bit and B) you can't cut them should they become warped. Besides, the ABS kicks in when I put the pedal to floor, and that's with the stock pads. No, plain jane OEM replacements and a good sport pad are all I really need. Besides, I've heard those drilled and slotted rotors can crack and break.![]()
They are what the pads chomp into when activated by the calipers (which contain/hold the pads).what are rotors?
Guys, Mikes talking about elephants againmfong said:I'm like a boy who wanders in half way through the conversation, i'm out of my elephant here.~Mike
You know Finn, you have a good point there. Here's the deal though, I'm trying a new pad out, I have no idea what it's going to do to the disc. The stock pads chewed up the discs pretty bad, and I don't want to be putting down money for expensive discs if these do the same. Plus, they're still 12 inch discs, they'll still rip my face off if I want them to. :cheesy:Finn said:I am confused, a warped rotor is a sign of to much heat. The idea of grooved or drilled is to stop the warping.. No cracking with a grooved disk only a slight possibility with drilled, having said that I have never seen a drilled one crack in recent years. With a grooved disk and a fast road pad the abs doesnt kick in as quickly. I used a metal compound pad a few years back before the ceramics were available, they used to get so hot on the smooth disk that red hot iron fillings used to pit my alloys.![]()
Hi metal content in a pad will often chew the rotors. If you need better stopping power then get a fast road pad such as Black diamond. If you need even better stopping power, ie you are getting brake fade. Then change the rotors to grooved, this will help the cooling and help brake fade and over heating to the rotors. Personally I will never go back to high metal content pads, for me ceramic is the only way to go.Raven18940 said:You know Finn, you have a good point there. Here's the deal though, I'm trying a new pad out, I have no idea what it's going to do to the disc. The stock pads chewed up the discs pretty bad, and I don't want to be putting down money for expensive discs if these do the same. Plus, they're still 12 inch discs, they'll still rip my face off if I want them to. :cheesy:
Obviously not the bit the pad touches! Here's mine:bobsaab said:Anyone else paint their rotors?
