88 900t clutch goes straight to floor,fluid leaking from front center of motor area. I just swapped trans. with a used trans.and used existing clutch cyl. however put in a new clutch. any help or ideas? thanks
Could be a hose too. The only hose is to the left of the slave cylinder (looking forward) and joins to the pipe. If the fluid is leaking out on the underside of the clutch cover on the gearbox, chances are it's the slave cylinder, if the hose is gone, it'll be soggy with fluid...
