1 - 7 of 7 Posts
Hi all. I recently brought my 2000 9-3 SE to get its A/C repaired, and when I picked it up...the shop said "oh...and in the next few months you should get a new belt tensioner"
Really?? Though I have a brand new belt and idler pulley, she said something to the effect that when she drove the car with the steering wheel all the way to one side, resulting in a weight shift...she felt a vibration...which she said was the result of an worn tensioner pulley.
Any thoughts on this? New pulley or pulley assembly? If I can do my own brakes, can / should I fix this myself? I don't have any specialized tools other than wrenches/screwdrivers. Your thoughts on this would be greatly appreciated.
Thanks. I'm not sure what you mean by "rack problem" - but what she said didn't make sense to me either. Are there any other tests I can do to rule out one issue or the other?
her chest prob shifted in her bra when she cut the wheel all the way. her own rack problem haha
rack problem- meaning issue with the power steering rack, if they mentioned the tie rods(inner,outer) or the mount that goes into the firewall. Any leaks?
The "shop" - I question their abilities to diagnose...and to stick to the assigned task (AC)...The tensioner is in two parts , a pulley and the rest (spring and housing)...
The serpentine drive system consists of many parts...it would be up to $1000 to replace all, which of course is un-necessary....I doubt if anything is seriously worn in the tensioner...If the spring was weak the belt would slip (squeak and squeal)..
If the pulley bearing was worn , then the belt could be thrown off, but first one would hear the rumble and roar of a worn out bearing..
Define "specialized tools" .....Doing the pulleys and belt is no easy task, IMO, not for a novice.
Although I will say the tensioner pully is one glaring weak spot on these cars and MUST be replaced every 40K. I've had 2 break on me at around that mark.
1 - 7 of 7 Posts
