Just spent the last hour fitting new grovved and cross drilled disks to my 91 turbo with lovely new pads.
Everything went smoothly and went to take it for test drive before doing the rears, started it and then found clutch pedal went straight to the floor :evil: :evil: :evil: :evil: No pressure what so ever
I assume it is the master cylinder. I am going to have a search but remeber Matthew did a huge write up with pics of changing clutch.
Is it worth doing this at the same time ? Is it such a monster of a job ?
Already have got a new clutch and release bearing waiting to be fitted but was a bit scared off as it looks a big job.
Do you think my diagnosis is correct ?
In the last couple of weeks it has had new rear springs and shocks, new recirc dump valve, new front brake discs, new front pads plus all silicon hose replaced. I have got new front shocks, clutch and release bearing, new rear discs and pads still to fit.
What more could go wrong ... actually I shouldnt say things like that. I assume it is just cause I am up to about 150K which is replacement time.
