1 - 7 of 7 Posts
I have a 1991 Saab 900. Would a tune up kit for a 1990 900S fit on my car?
  1. Distributor Cap - Bosch 1 235 522 056, Saab 7501216
  2. Distributor Rotot - Bosch 1 234 332 370, Saab 7564420
  3. NGK Spark Plugs (4 plugs) - BCP6ES
  4. Fuel Filter - FF767 (from Autozone)
  5. Valve Cover Gasket - Saab 9549593
  6. Valve Cover Nipple for Vaccum Fitting - Saab 9549593
  7. Air Filter - Same as Saab 7514722
  8. Auto Transmission seal (for drain plug) - Don't have part number
  9. Front Crank Seal - Elring 93 09 204
  10. Distributor O-ring (5 pieces) - Saab 9176470
  11. Fuel Filter Sealing Ring (2 pieces) - Saab 4161162
  12. Fuel Filter Sealing Ring (1 piece) - Saab 4443883 (note: you need 2 pieces when changing fuel filter)
I'm not really sure,could you make the text a little bigger please.
Did the 2.1 not come out in 1991? THen some part could be differernt is you have the 2.0 B202.
It is the 2.1L base model, 16V. Do you think those items would fit? Just may have a great deal on all of that equipment...and save probably several hundred dollars, but I do not want to buy it if the parts won't fit.
I feel like the distributor may be different, but everything not related to that will probably work, and the cap/rotor are cheap anyway. Not sure about the valve cover gasket, but I'm pretty sure it's the same.
1 - 7 of 7 Posts
