It's always been a chore to get the dial gauge set up to measure run out of rotors and wheels... no good place to stick it, even with the magnetic / adjustable base. Sitting it on the ground always means that it moves around a bit (although you can stick it to a free-weight and it's more stable, if the ground is flat).
But at last: I came up with a mount that is solid, stable, easily movable, and fully height adjustable!
Editor's note, slightly off topic: Realized rotor doesn't actually turn with all the studs in. You need nuts on them to shorten them up, or a set of short bolts.
272269
Clever! I have one from Harbor Freight that has a clamp mount. I attach it to either a strut bolt (on the 9-5) or a caliper bolt (on the NG900). I haven't used it much, but it did help to fix a vibration in the front left of one of my 9-5s. The rotor was slightly out of spec, but a few pieces of aluminum foil between two of the bolt holes fixed it right up.
STEEL JACK!!! ARE YOU SUPERMAN???
Yes, but regardless, I'm not holding it up steadily with one hand while spinning the rotor with the other :)
Clever! I have one from Harbor Freight that has a clamp mount. ...
Same one, but I can never get as solid as I like no matter when I put it. The caliper based works for rotors, but not for hubs or wheels. Maybe the carrier mount would work for hub although I think you need a third arm on the mount to get to the outside surface. Haven't tried.
Caliper mounted IS a better choice in front when you can use it since the wheels can move and that kills accuracy. I haven't quite figured out how to lock the steering rods or struts in tight although I'm sure it can be done. I've taken to measuring wheels on a rear hub to avoid the issue.
