Uuugghhhh. Thanks in advance for any suggestions. Battery good 12.5. When you turn the key all interior lights dim but no start. I checked all fuzes and took cowel off and opened the relay box under drivers side When you turn the key you can hear the relays click. I swapped the starter relay with the fuel pump relay. No change. I am at a loss. Please help. That was my back up car. And my current drivers tranny is almost gone. Thanks again
You could spray large amounts of WD-40 down the slot in the ignition switch. It displaces water.
I would also disconnect the battery, open all the doors and windows, and let it sit open for Friday and Saturday. It's supposed to be relatively warm and dry in your area. It will let it all dry out.
Hi all.. Neutral switch. Was the issue
Thanks for all your quick replys. Am going to continue the drying process over the weekend. Took the suggestion of trying neutral after moving the shifter all the way up and down a couple of times and she started. Let her run for a little. Shut her down , disconnected the battery and let her spend a day in the sun. My car has a better life than me. Swedish B&$;h
If you can put a large electric box fan in one door and let it blow out the other side for a few hours during the hot part of the day that would help dry it out quickly.
