1 - 9 of 9 Posts
I bet my wife that our son would way over 9lbs 8 ounces and he came yesterday @ 10lbs 6 ounces! I win a GS rear bar. I went with the 25mm. I was curious if any of you added this part seperate from the 6 point and if so which was the biggest improvement in handling?
Eibauch Springs, Blilstein dampers.
3''dp, and saab sport exhaust.
when i added mine i disconnected the front sway, so i couldn't tell you that mod alone, but it was a good choice. You won't be disappointed
Congrats on a healthy baby.
I did them all in one day, but I test drove in between; lucky for you the ARB wasthe first one I did.
It made a big difference, but with the others it was way, way better.
mfyoung said:
it helps my track in offroad, being that i don't have to counterover steer as much to get the *** to slide out
works well on the autocross track, although wheelspin became a slightly bigger issue, nothing to whine about tho
ok I gotcha.
I had a 22mm SAS sway bar without anything else and I was very pleased with the results it made the handling feel more neutral, but still at the limit it wont send you into a spin in snowy weather. Scandinavian flick does make it the tail end kick out though :)
1 - 9 of 9 Posts
