1 - 13 of 13 Posts
I am going to put a Kennwood head unit in where my current CD player is but I can't find what wiring harness I need. I am keeping the original head unit in can I just take it off of that? Thanks!
There is no wiring harness for the 2005 9-3. The stock head unit needs to stay in the car for it to start.
what you see in the dash is the control panel the actual h/u is behind the ac panel..
Okay, so how would I be able to hook the speakers up to the Kennwood head unit up to the speakers? The speakers are all amped and there are 7 of them, plus I want to add a sub
You would have to tap into all the speakers and bypass the stock sound system completely.
he means that if you mess up the stock headunit and its connections then your car won't work
this,the fibre optic loop doesn't just do the car audio it links other systems aswell..
why not just change the dash & rear shelf speakers & add a decent 4 channel amp(bridgeableto 3) which can run a pair of 6x9's & a sub.. or just add a sub
1 - 13 of 13 Posts
