Hello
My driver side wiper is loose (very). I tried to tighten on the bolt, but there is so much give even when it's the tightest. The rubber cover is not even touching the plastic.
How do you get under the plastic cover the wipers are sat on, I suspect there's another bolt there?
Are you sure? The arm goes up and down but with a lot of give, so it goes "ba-bang", "ba-bang" as it rolls up and down. Its not nearly as tight to the window as the passenger side
Dismount wiper arms with small puller.
Remove sealing lip. At least on a single side it should be removed from body by gently dismounting the lip from the clips and leave clips in body)
Pull cover slightly over firewall and remove cover by pulling it downwards (there are easy to brake clips under it which snap to windscreen)
Check linkage.
