1 - 7 of 7 Posts
The stock size for my car (2005 2.0t) is 215/55 R16. I have a set of winter tires available to me that are 215/65 R16. Will these tires fit or am I asking for trouble?
Thanks,
KNG
Yes they will fit, you will not have problems. A Winter Tire is usually taller and narrower, your just choosing to go taller. It is a dedicated Winter Tread though right? IMO "Looking Balloony" is Hooey. Members here will tell you Winter tires are Narrower and Taller, and most use dedicated rims...
Many thanks for the reply. I have a dedicated set of OEM 16" for winter tires. The tires I have on now are 205/60 R16 Kumho KW17, they are done. I have access to a set of Toyo Observe G-02+ for next to nothing but they are 215/65 R16.
Is it safe to put a set of 195/65 R16 on the OEM 16"x7" rim? Same height as OEM, but narrower. How narrow can you get away with?
KNG
I can't authoritvley answer the Q about how narrow you can go on a 7" Rim. I'll venture a guess, and could be wrong, if the stock size is 215, you could be OK with 195. But get that confirmed by a Pro, not an SC opinion.
I'll agree w/ Jon as far as a 20mm reduction likely not to cause problems.
For reference, I run the stock size for my Aero - 235-45-17 - for my winters. Not too sure what kind of snowfalls you get in Calgary, but despite not being "narrower and taller", I managed through a tough Erie PA snowstorm (lake-effect hell) without problem.
Growing up in this stuff, it comes down to a good tire and decent knowledge.
Hard question but a fat tire is not the answer in snow. Calgary? Got snow? It's a series of compromise, fast on a skinny in the wet ... no way.
Soft compound or radical tread and your handling and wear are kaput?
1 - 7 of 7 Posts
About this Discussion
5 Participants
TunnanXWD
SaabCentral Forums
Full Forum Listing
