My wipers will run but no fluid comes out. The fluid tank is full. I can’t seem to locate any leaks.
I pulled the insulation hood cover off and all of the tubes and values are in place for the washers.
My check engine light went on 2 weeks ago when this started happening , but then went off after 2 days. Any ideas?
Check fuse 22 for the washer pump in the engine bay fuse box.
Your pump has probably shorted .........common problem especially when operated without fluid or when frozen up
Thanks. I’m going to pull the fuse later and see how it looks. If not the fuse - I guess it’s the fluid pump!?
