9-3 MY07 convertable vector - has climate control and in the manual it says there are two options for the windscreen blower
One Press demisted - highspeed fan , defrost vents, recirc off, rear window/door mirror heating
Two Press just air to windscreen
to revert press auto
when I press the windscreen button - it turns ON - but a second push just turns it OFF
is this feature on my car or am I mis reading the manual
Does the indicator light go off as well?
On my 07 S/S upon the second push the fan gets real quite but doesn't go off.
I find this part of the vehicle the hardest to understand.
yes, i think the light goes on and off - does your light go on and off with each push?
My light stays on. In fact I can't shut it off.
I push defrost once, full fan front comes on and back defroster comes on. Second push the light stays on, if I push it again the light stays on, it may be on a timer because I selected to have the rear defroster come on automatically with the front.
You know, even reading the manual does not make understanding the operation of the ACC easier.In fact the salesman had a difficult time explaining it. Then add the fact that you can go into the SID and change settings doesn't help matters either.
thanks - i played earlier and yep
one push = fan and heater and light stays on
2nd push - fan and heater goes off but light stays on
when I had the temp up high, it then changed to the car ....
i will have to look at the SID and see what i can change too..
thanks for the input
