Hey guys simple post here, i was just curious how annoying it is to replace a front driver window regulator? I am buying a new door and one is 175 without the regulator and one with it is 250. Honestly would it be worth it to spend a little extra in your opinions? It looks like 45 min job of tediously pulling the regulator out of the door but i could hopefully be wrong. Thanks guys let me know what you think
I spent about an hour working on the door handle from inside the door. In the end, I gave up and decided it wouldn't be so bad to climb over the shifter and out the passenger door every time I drive the car...
I'd drop the extra $75.
I once replaced the reg in a convertible. Drilled out the original rivets and replaced with bolts. It took a couple of hours, because I'm just an amateur tinkerer, but its not a big deal. I don't recall involving the door handle in the process.
