1 - 11 of 11 Posts
Are there any DIY instructions on replacing the window regulator?
I did a search and found some pictures of the regulator with the wire path, but that wouldn't really help with the install. I have one coming that I found on ebay for $100! (plus $15 shipping). I think I can do it just fine without instructions, but its always much easier with them. If not, I will try to document as much as possible with pictures and post it on here.
Thanks!
This is probably not what you are asking for but I had mine done under warranty for $175.00. It didn't cost me any money but when I looked at the bill I saw that they charged $175 to be reimbursed from GM. It took more time to wash and dry the car than installing the regulator (half an hour).
the service techs actually dry your car? I have started asking for no wash when I go, because I find lots of white soap spots everywhere on it.
Half hour!!! Great!
So if the actual service place can do it in that time, that gives me, hmmm, about 10 hours!!
Dealers get reimbursed by Saab at a MUCH less rate than what they will charge you. You're looking at a several hundred dollar part and several hundred dollars of labor.
Had two done (failed within 24 hours of each other!) recently and it was something like $300 each with fees and tax. But that was for the regulators w/o the motors, which were fine. Shop around. In this case my dealer was actually LOWER than the independent Saab shop we use.
I found some info on the web (sorry, didn't keep it) and it looked daunting enough to just let the dealer do it. I think the labor was about half of it. I'm sure it's something that's easyonce you've watched it being done, but I didn't want to get halfway in and do something wrong.
I actually just began a write-up yesterday on how to replace the regulator, including problem diagnosis and part numbers. I've almost finished but still have a few pics to put in and some re-organising to do. I'll try to get it posted in the "How to..." sticky.
I'll let you know in this thread when it's done.
ok- don't mean to steal the thread but, serious question regarding this window regulator. I have a 2003 9-3 with a bad window regulator. I was reading numerous posts about this stuff and is it true that the part for the 2004 has a stronger piece of plastic by the motor part. (the piece that the two cables wrap around)(the 2003 is a white piece and the 2004 is a brown piece??) .. IF so, will the 2004I hope this makes sense to someone. Because i do not want to buy a $180 part to have it break in one year if the 2004 part will work..
thanks, in advance.
Discussion Starter · #10 ·
ryanr,
I got mine done over the weekend. Extremely easy. Took me about 1.5 hours. I recommend DIY to anyone who is at all mechanically inclined. I took pictures so I will post when I get a chance.
The regulator I received (don't know what year it came from) had the brown plastic sliders. I paid $100 for it used on ebay, with $15 shipping. I don't know what the dealer was going to give me but it would have been $175. The parts dealer said it is a very common problem so I imagine the parts are a better, stronger plastic.
Hope this helps!
1 - 11 of 11 Posts
