1 - 20 of 29 Posts
Are window regulator failures very common in our 9-3ss? Mine are fine so far, but I was wondering if all the failures being reported are in a certain model year, or what.
2003? 2004? 2005?
Please post any failure experiences in terms of model years. Thanks.
Yo. Right here.
Driver's went out, and I think passenger is on it's way.
I think a search will reveal that this is a rather common 2003 issue. There's quite a few 2003 members that had it bust.
Mine was experienced by hearing a light "pop", and then about 2 days later a rather loud crunch. Then, the window wasn't really attached to anything, and would only stay up if I jammed it up into the weatherstripping. :roll:
Passenger did the small pop, but will be replaced under warranty as well. Nice dealer!
Add another to the list. Passenger side stopped working a couple weeks ago and just made ugly sounds when the button was pressed.
Part to fix is on a national backorder with no eta for the parts. I'm thinking Saab needs to contact VW about how NOT to handle the problem.
And to top it off, my wife keeps trying to use the window daily. Today it fell down about half and inch but I was able to jam it back up into the weather stripping. Repeatedly telling her that it's going to fall into the door doesn't seem to help her stop.
Me too. 2003 Arc. Passenger window.
After being told by dealer parts were on back order, they called back a week later and said part number was discontinued. They were working on gettting the appropriate substitutes. They said bring her in Monday and they'll work the issue. They have 4 others on the lot waiting for the same thing.
wish me luck, and good luck to you guys. i am tired of manually forcing the window up into the weather stripping before each trip (if I don't, it whistles on the highway).
GP
My drivers side went out in May, but they replaced it real quick, seeing as how it woulding go back up. :roll: This was a huge problem in my last three grand ams.
The info you need
My drivers window went twice in two weeks. Did not hear the pop but if you do it is the spot welding giving way. After a certain VIN number the part was replaced. If you search a little you can find my recent thread with all the info.
This info is thanks to edusaab:
Checking the parts that it was changed from one year to another, there is the mechanism of the support of the window.
the cars before the chassis number 31034551(those are the last numbers of the chassis) they have a specific support mechanism.
After that chassis number they receive a new part, for the Left door, the part number is 12802320, and for the right door is 128802321.
Repairing is not good enough, they must replace with the newer part.
Driver's window went around 10K miles. I rolled up to a toll booth and the window wouldn't roll down so I had to open the door to pay the toll.
This was never an issue on my previous two SAABs, or at least not a commonly heard of issue. Thank you, GM.
My driver's and passenger's front windows both had regulator replacements at certain points last year.
To top it off, yesterday the weatherstripping on the driver's side window started to disintegrate and crack, so I can't roll the window & down properly.
You know, in 1987 I bought a $6000 Dodge Colt:
The windows always went up and down;
The windshield wipers always worked properly;
The windshield washers always worked properly;
The gas gauge always worked properly;
Plastic pieces on the car never disintegrated or ripped.
I cannot make those five statements about my $25,000 2004 Saab 9-3.
This thread seems to be related, so forgive me for just jumping in!
I have an '04 9-3 Arc, and the passenger window "went" on me today. No movement, just a clicking sound in the door switch when the up/down is pressed.
Any ideas? Which part is this? Thanks!
2007 93 2.0T. both rear windows had to have regulators replaced within the first 15,000 miles of ownership. so far (knocks on wood) thats the only problem Ive had with my 93.
Driver side replaced last year, pass. side last week....PITA but DIY for under $150.00 each.
FYI, while replacing, if you think the motoor may have died, there is a little black rubber button on the motor..I found out it must be a reset...WHEW, saved me $250.00 more..
Window regulator
the passenger regulator went out in mine found the part for 80 bucks online and put it in myself it took about an hour wasnt too difficult
Both front driver & passenger went on me within 8 months of each other. Its a very simple DIY job. These sell for approx $150 (as stated above) delivered.
Window motor
My 2004 9-3 ARC vert motor died yesterday. In that car the motor and regulator are 2 different items.Saab wants $340 for the finger protection motor and $377 for the non finger protection motor (mine). The regulator is $377. plus 1 1/2 - 2 hours labor. My independent shop is $340 for the motor i need. Maybe the reset button w/work. We will see. next week.
2004 here, and already had the driver side regulator go, now the passenger side is making the same impending failure clicking noise.
Yep... same problem
I bought my 2003 9-5 Linear in November, and the windows never worked (turns out they unplugged the power clip to the windows so that people wouldn't mess with them on the lot and they also bent the regulator frame to hold the window up instead of just buying the new rollers that it needed) and I just figured it was an electrical thing so I bought a new switch, waste of 50 bucks. Then cracked open my door panel (once to see what was up and the second time to put the new green regulator rollers in) and spent multiple hours trying to figure the stupid thing out. Not very happy that I will have to replace my front window regulators because people are lazy and don't know how to fix things.
Thanks for helping me figure out that is what is wrong with it, though.
Window Issues
I have a 2004 93 Aero and I continually have window issues. I've had my driver's window repaired 3 times. It would go all the way up and then go 1/4 of the way down. Go to put it back up and then window would go all the way down and then back up. After a few months of that it just woudn't open. Now the passenger front and back are doing this...1 month after getting the driver's window fixed. Is this an on going issues in Saabs? Has there ever been a recall on the windows?
Seems like more of a problem in northern and saltier climes. Never open windows if the cars been sitting out wet and frozen. The plastic runners that hold the window and slide in the tracks break. Ive been looking into the Caddy CTS regulator that has metal runners and seeing if theres a retrofit possible. They are really close and only $50.
1 - 20 of 29 Posts
