1 - 7 of 7 Posts
My driver's window is stuck slightly open.
How can I tell if it's the lifting unit or if my motor is going out?
Just to be an extra punch in the nuts my AC stopped blowing cold the morning after my window gets stuck! :x
I fit still goes up and down, the motor is probably fine. What you want to replace is the window regulator, which has a plastic spool that the window lift cable wraps around. Over time the cable eats through the plastic spool and stops lowering/lifting the window correctly. If you've been hearing a popping/cracking noise when the window goes up and down, then it's definitely the regulator.
Hi there. I guess I am having the same struggle.
Post picks and whatever on your outcome to this fix!!!
;ol;:D
1 - 7 of 7 Posts
