What Volvo is it from? If you're referring to a Garrett, I wouldn't bother using that over a TD04. I take it it's comparable to the GT17 used on the Linear, so it would be a better idea to upgrade to a TD04HL-15T or larger.
If you are indeed talking about the Mitsubishi -15T turbo the CHRA might fit but I doubt that the exhaust and compressor housing are the same.
you could check the banjo bolts to see if they are the same with the Saab turbo as a first check.
But if you're looking for a complete turbo swap with the lines I highly doubt it since the location of the ports for oil and coolant are nowhere near common between the Volvo I5 engine and the Saab I4.
I'm just curious as to what Volvo a 15T would have been removed from. '94-'97 850 Turbos used a 15G, but that's as close as they came to a 15T.
If you want to use a 15T, just get one off a 9-5 Aero.
