Status
Not open for further replies.
1 - 10 of 10 Posts
hi guys
i recently fitted a aftermarket induction kit onto my 2.3 T and since it has a lot more wastegate chatter and turbo whistle
but it also makes a wierd induction noise normally at half throttle between 2-3k revs , it sounds like a "bull being grabbed by the horns and pulled" its just a droning kind of noise
has anyone else experienced this???
the engine runs fine it just makes this odd sound, if others peoples cars do it then it doesnt bother me but i think the size of the filter may be causing this. it is a large K&N off of a RS turbo, modded to fit the 3" inlet on the saab
thanks in advance
Jim
I have search for a "bull to pull" and cant replicate that noise :cheesy:
Mine has a huge N&N and is very noisey, wife thinks it sounds like a tractor, kids think it sounds like the air brakes on a bus when the pressure is dumped!
Maybe they get quieter whn the filter gets a little dirty? :confused:
its not an induction "roar" like i have had on other cars though, its a "echoing" noise through the intake pipe by the sounds of it,
its also starting to stall if i brake quite hard with the clutch in when im in traffic so i am thinking of taking it off again
if the filter is too big would this cause too much air to be going into the engine
i drilled holes in the standard airbox before i fitted the air filter and it made this noise but not HALF as loud and intrusive
thanks for the reply :)
Jim
I doubt that's possible, seeing as you're still pulling air through the turbo. The stock intake is designed to muffle an undesirable noises, maybe you are just getting an echo. Could you maybe record the noise?
i could do , i will have a go tommorow and see how i get on , its also stalling now when ever i accelerate quite hard and then push in the clutch (coming up to a junction etc), it didnt do it before i fitted the filter so it isnt helping it much :(
Does like a loud FMMMMMMM noise, almost like a vibration. Cause my car has been doing that to, but no trouble accelerating or anything.
Jim this doesnt make sense, are you sure there are no vacuum pipes off, perhaps dislodged when the filter was fitted? :confused:
i cant see any that have come off but the stalling problem still persists, i have posted a thread about it,
the horrible noise irrated the hell out of me anyway
the wierd thing is it only stalls if i accerlate hard then push in the clutch and let the revs die right down
Jim I'll close this thread as we are now trying to solve this in the 9-5 workshop ;)
1 - 10 of 10 Posts
Status
