OK, now it sounds like you have a different problem. Better have your wheel alignment checked by the dealer. Once the alignment checks out OK, re-do the wheel balancing again. I am asssuming you are using Saab rims. If not, make sure they replaced the hub adaptor, otherwise it will cause the wheel to wobble too. If they can do on-wheel balancing, ask them to do that and see if it makes any difference. If all else fails, change to another model/make of tyre and see if it makes any difference.
Did you ever notice that red dot and yellow dot on new tyres? You are supposed to align the yellow dot to the valve stem. The yellow dot marks the light point aka weight mark. The red dot marks the high point ie. the wobble point. This is also known as the uniformity mark.
If the tyre shop doesn't know this, they ought to be shot! I always make sure that the shop guys do exactly as I tell them including ensuring that they align the dots to the wheel. This way minimum number of weights is required to balance the wheel. If they put too many weights on the tyre to balance the wheel (assuming they align the dots), 1 of 2 things is wrong, the wheel has a problem or the tyre has a problem. Usually its the tyre. Generally anything more than 25g is way off.
Hope that helps.
