Rob in Atlanta said:There are three reasons that have prompted SAAB to put a V6 in their top of the line 9-3.
1) V6's are more refined by nature - they have less natural vibration than a four. Now this is a relative matter. There are some poorly designed V6's that are less refined that some fours. That caveat being said, V6's are generally more refined. The one being put into the Aero, by all accounts, is a very well designed, highly refined engine.
You are headed in the right direction here. An inline 6 is the only engine with a true inherant balance. With an Inline 4, balance shafts are almost always required to quell out vibrations at idle speed as there is still an instrument-measurable pulse from the engine where there is no power being produced, hence an idle shudder. With an inline 6, all of the pistons being on the same plane with at at least 1 firing at any given time, there is no full lack of power being produced. Engines in a "V" configuration, while smooth for the most part, do not work on the same plane therefore producing minute vibrations from intertia of the moving parts.omerulas said:Well, phisicaly it's impossible that a V6 produce less vibration than a R4 engine. The even numbers of pistons on the same crank shaft will move symetrically and reduce vibration it's one of the reasons why BMW insists on R6 engine.
The V6 is a turbo too, Why would you not expect a lag on the 6??? Lag from what I know comes from the turbo. If you want to minimize lag you can add a smaller faster spooling turbo for low end grunt and a larger turbo for top end like in the last gen Supras and 3rd en RX-7. To eliminate lag either go all engine or Supercharge it!!! Correct me if I am wrong but number of cylinders have no bearing on turbo lag.clarkkent said:I test drove a 9-5 Aero 5-spd before I bought my SS. I have 2 words, TURBO LAG!! I bet that is why Saab didn't go with the 2.3T in the SS. The V6 will be much smoother.
A V6 would feel less laggy because it would have more naturally aspirated pull before the turbo were needed. I drove an Arc and an Aero at my retailer earlier, and the lag was very noticable, but also very fun to play with, at least for me.Saabless said:The V6 is a turbo too, Why would you not expect a lag on the 6??? Lag from what I know comes from the turbo. If you want to minimize lag you can add a smaller faster spooling turbo for low end grunt and a larger turbo for top end like in the last gen Supras and 3rd en RX-7. To eliminate lag either go all engine or Supercharge it!!! Correct me if I am wrong but number of cylinders have no bearing on turbo lag.
Not at all the case, the ecopower is one of the greenest engines around.Aero_adam said:- I expect that the 2.3T that has served the 9-5 and 9000 so well for years may be struggling to meet the increasingly stringent emmissions regulations.
I really don't think it's that laggy, as long as it's above 2000 rpms the power is almost instant.I test drove a 9-5 Aero 5-spd before I bought my SS. I have 2 words, TURBO LAG!! I bet that is why Saab didn't go with the 2.3T in the SS. The V6 will be much smoother.
The exact opposite is true, the 2.3T is significantly better on emissions than the new 2.8V6..... :roll:Aero_adam said:- I expect that the 2.3T that has served the 9-5 and 9000 so well for years may be struggling to meet the increasingly stringent emmissions regulations.
It is true. Combine the lower emissions with much better fuel economy and it makes me shake my head! I love the 2.3T engine. It truely is one of the best all around turbo engines out there. Doesn't it's use in the Viggen show you that it's Saab's gem? Although, I guess I don't love it enough to purchase a 9-5!aeropilot said:The exact opposite is true, the 2.3T is significantly better on emissions than the new 2.8V6..... :roll:
In fact the 9-5 Aero HOT fitted even with an automatic transmission has a lower CO2 value than the new 9-3SS Aero 2.8V6 fitted with a manual transmission....![]()
Saab published figures for CO2 emissions are:-93Linear said:just out of curiosity ... do you have/have you seen some sort of fact sheet(s) that show this?
