1 - 11 of 11 Posts
..and what did you use? I have a bent wheel and bought an eBay replacement used. It's perfectly round but has a bit of curb rash that I wanted to at least repaint....
check out stx221's wheels
thread here
Thinking about doing the same to the 04 Aero 5-spoke wheels I got with a little curb rash.
Thanks! But I need a little more how-to. I know there has to be someone who's just touched up one wheel. Where to get the factory paint???
You're right, there have been people who have touched up just one wheel. Quick google search brought up this. http://www.bmwtips.com/tipsntricks/wheel-repair/wheel-scuff-repair.htm
It seems simple enough, and the results look quite good. I feel like it would be easier to remove the wheel completely and paint elsewhere, than to mask the whole car like hat guy did. [shrug].
Sorry, don't know about the factory paint. Good luck; let us know if you find out.
Yeah but I wonder if that guy had three kids under 5 and a doctor for a wife?:cheesy:
So you see, my time is, um, limited.:(;) I know someone on here is bound to have done this. Maybe 9-5s are too new for many to have bothered. Perhaps I should check in the 900/9-3 forum?
Looks about right...
I think I remember someone referencing that bmw DIY before. It seems like that would be the correct process. I also think that is where I heard that the wheel paint is the same - or someone said that Saab and BMW use the same paint
Maybe you can slap on your donut and take care of the wheel out of reach from the children's over a couple of nights and spray the wheel during the day when it is warm enough. (will it get warm enought to spray in January down there?)
Oh, the wheel is a spare replacement I am putting on. I wouldn't have any problem taking it off (since it's not on) and even taking it to someone but I just want to make sure that it's well-done and matches the other wheels.
Well, I will put my couple thoughts in here since someone brought my wheels up.
By no means is the paint I used a factory color.
But the process was simple, and if it was just one stock wheel and i could get the same color, I would have done it slightly differently.
Process:
1. Dismount tire (not 100% necessary, though it makes things much easier).
2. Sandblast the old paint off (if i were just finishing one wheel, i would just scuff with like a 400 grit sandpaper).
3. Lay down some primer.
4. Paint.
5. Clearcoat (although with stock wheels, i am not sure if this is needed.)
You might try calling EEuroparts on this product:
http://eeuroparts.com/productdetail.aspx?searchResults=1&code=6596
And see if they think it will match your wheels.
Worst case, if you had to prep and paint all 4 wheels so they matched, I am sure that you could do it all in a Saturday, and then just let them dry for a day or so. It sounds like you are very concerned with them all matching 100%, so this sounds like it is probably your best bet.
You could also paint one at a time if that would make it easier (since it sounds like you have a 5th wheel to run on there for a couple hours while you paint) and you could paint one and then paint the next one 3 days later.
Or maybe it is just time for a wheel upgrade ;)
Discussion Starter · #10 ·
I've got a replacement, it's just got a little curb rash. But you know, after I pressure washed it up along with some Meguiers wheel cleaner, it looks new from more than five feet away. I wonder if I got it off anyone on here? Someone selling 4 on fleabay in Mass? It's the old ten spoke stock 9-5 base wheel.
I wanted to replace one of my wheels due to some scraping from curb rash but not sure if its a 16" or 16 1/2" rim...how do you tell the size for appropriate wheel size. The tire says R16. So is it a 16" rim?
1 - 11 of 11 Posts
