900t said:
Normally if you put M1 in the gearbox it will shift balkier than it ever has balked at before :lol:
Well, honestly I think the gearbox needs a rebuild, syncros are probably just worn, when it gets cold out, it occationally grinds going into 1st (this really only happens a few times a winter) but overall its been getting harder and harder to go into gears. It's not grinding, its like there is something in the way. It might be the rubber coupling too I suppose, do they tend to act up in the winter when they are shot? Once you get it warmed up it gets a lot better though, almost back to normal warm weather operation.
Anyhow, I'm running the clean 5000 10-30 right now, and it does fine in warm weather. :roll:
I thought I'd give synthetic a try, see if the different viscosity/charactoristics might help in the cold weather. :roll:
I've done so much to the car that I hate to just park it but at the same time it needs so much more to really bring it up to spec that I hate to go to all the trouble of rebuilding the trans, repainting it, etc. I can do all that, I could shoot some PPG omni on it for less than $200, and provided all the parts are still available, probably rebuild the trans for less than the same, but jeeze thats a lot of time and trouble and when I was done I'd have a really nice N/A. So then I'd have to do the N/A to turbo convertion....
