trying to install a Dice universal integration RDS kit to connect ipod to radio. It works by connecting to the antenna which is typically on the back of a car radio. However, with SAAB it is no where to be found. Not on back of radio, not in trunk, not in passenger side c-pillar as the manufacturer suggested. The only antenna there was for the on-star phone. radio antenna is integrated into the rear window, but I cannot find where it connects. Any advice will be appreciated! Thanks. DG
the radio antenna connects into the back of the EHU, which is located behind the ACC controls. the antenna connector is not a standard type but is a FAKRA connector which means connecting into a kit will be difficult but not impossible, you'll need a couple of adapters.
One to change the fakra to standard to connect to the kit, then one that is standard to fakra to connect back into the EHU.
The white connector on the right of this pic is the fakra antenna connector.
Photo came from these aux install instructions: 9-3SS Aux-in Cable DIY install
