1 - 2 of 2 Posts
Hey everyone, new to the forum and this is my first time posting so I figured I'll give a little bit of background.
Bought my first Saab about 3 months ago, and completely and hopelessly fell in love with her. A couple of weeks ago though, things nosedived when my head gasket blew. Since I manage a local automotive shop, I towed her in, stripped her down, expecting to drive her home that night, only to find that I have at least one piston that's chipped. Which would explain my oil blow by thats causing my pcv valve to leak like a siv...
Apparently this is a fairly common issue with the stock T7. Now I'm left to wonder what to do next?
Should I just swap out the pistons, or do a complete overhaul? I'm planning on doing as big of a build as I can over time, but was originally going to follow the tuning thread's advice and start up top. I have another car as a daily driver so if the engine needs to sit on a hoist for a few months so be it 🤷‍♂️.
If i were to do an overhaul (crankshaft, rods, pistons, etc.) Any recommendations? Should I bore out to a 90.5? Higher compression ratio with custom pistons? Or would I run into problems with the block if I get too fancy? I'm not necessarily wanting to race my Saab, but I do want to try to get as much HP as I can out of this build (WHILE keeping the car's overall integrity in tact long term).
Thoughts?
You need to research the various performance stages. At some point, you have to go to forged pistons in a T7.
It's a turbo engine, so boring it out won't do a lot of good, and increasing the compression just gets you into detonation.
Your first step is to see the state of the cylinder walls. It's probably better to get a good block than to start machine work on a damaged one. As far as I know, even a sludged engine dies due to bearing failure; it's in the extreme case where the cylinder walls get damaged, by a broken piston or ring.
1 - 2 of 2 Posts
