Hello, I have a 1999 9 3 five door hatchback and the rear window recently was busted out in a hail storm. I am looking for a used or salvaged window. Does anybody have any ideas on where I might find one. Thanks.
Try using www.car-part.com, look for an entire rear hatch as well as just the glass.
I'd expect you can find one in the greater OKC area. Pretty sure the glass is the same on the NG900 as well.
Should not be that difficult to find.
Too bad you aren't near me, as there are several good ones nearby for cheap. Trouble is, you need a PRO to remove and replace as windows are very easy to crack and tricky to remove. I'd call a local auto window place and let them worry about it. I've had windshields replaced over the years that way. Usually, you can leave a check in the car and leave it unlocked in your driveway, guy comes out, fixes it, and leaves a receipt. Very nice if you need to work and don't want to waste a day off.
