G
I'm looking to complete the conversion of my 9-5 to aero spec. It seems pretty difficult to source these however i was wondering if i might be able to use some from a 9-3 2.0 HO. The two share turbos and manifolds so why not cams? Any thoughts?
If you are going to that much trouble find some B204/B234 Turbo cams.. 900 9-3 94-99 turbo 2.0 or a 9000 2.3 Turbo 94-98 Be better in the long run.. Maybe cheaper.
Nick I was considering getting some T5 cams myself. Will these effectively raise the powerband or widen it? I'm almost complete with hardware mods and I plan on going straight to a Nordic stage 3 ECU. If I had the T5 cams will that change the programming for the stage 3 slightly? Cheers.
**nevermind already talked to Nick about this!
You're having trouble cause they're the same as the exhaust cam on the 2.3 LPT, only the intake cam is different.
I'm with nick though, get T5 cams, they're more better. ;)
