Maybe it is similar to Audi/VW fill.JHZR2 said:No guarantees that it is dexcool.
I went to the dealer to see what their coolant looked like, and it is long life coolant in a SAAB 4L jug. Has multilingual text on the back, and I believe it is a european product.
If it was dex, it liklely would have come in gallon jugs that look like those in the shelf of your favorite store.
JMH
My 2005 manual says it's a lifetime fill. I was going to trust it but I may change my mind in 3-5 years.JHZR2 said:The saab manual?!? I could have sworn that it claimed that it was a "lifetime" fill.
JMH
I am going to check this evening....I think I will change mine in 4 years together with brake fluid.Dave 37 said:My 2005 manual says it's a lifetime fill. I was going to trust it but I may change my mind in 3-5 years.
so what do you think Saab defines as "lifetime"??My 2005 manual says it's a lifetime fill.
Saab states every 4 years for fluid. I just sold a 1997 Nissan Altima with 205,000 miles on it. It had original brake fluid, and original front rotors! Although it did not have ABS, those brakes were the best I've have ever drivven....JHZR2 said:brake fluid should be done every 2 years, max... My BMW reccomends yearly.
I am considering just sucking all the fluid from the reservoir on the firewall every so often, replacing with new fluids to keep additive content up high, and keeping things fresh.
JMH
did you coast to a stop or just never stop?with 205,000 miles on it. It had original brake fluid, and original front rotors!
No, the car was used for a heavy commute to Chicago. Nissan makes good brakes on some cars.... I kept replacing pads and measuring the rotor and it was always in spec, did not need cutting or anything...I was amazed...thomjam said:did you coast to a stop or just never stop?
Jaime
My 2003 Manual states that Coolant should be replaced at 100,000 or SOONER. Sounds like a 60k item to me in addition to the plugs.thomjam said:so what do you think Saab defines as "lifetime"??
Jaime
